LEGO Powered Up App 3.0
Založil peki, 12.12.2019, 08:26:35
Dejte to podle uvážení kam to patři.
I'm happy to share the following upcoming app update from the Powered Up team - this new version is out soon (it's currently in BETA and going through app store's approval process):
Ready for an early Christmas present? We are super exited to reach this milestone in our digital system in play, with LEGO Powered Up 3.0. With this update we hope to further empower your creativity and enable all of you to rebuild the world. Also, we have a fresh new look!
What's new?
·         For those of you that have more than one hub, good news, you are now able to connect, address, code, and control multiple hubs (up to four actually).
·         The app now fully supports the new LEGO TECHNIC hardware. You are now able to connect the new LEGO TECHNIC hub, and use the internal tilt sensor, as well as the new LEGO TECHNIC motors. For the real techy ones, the app can read values from internal sensors (orientation (X, Y, Z), and acceleration (X, Y, Z) of the TECHNIC Medium Hub (Hub128). From the app you can pair motors on port AB, and CD. The app also supports the TECHNIC Large Linear Motor (Motor no. 2) and TECHNIC XL Linear Motor (Motor no. 3). From the app you can regulate power, speed and position of motors.
·         Last but not least, the app has gotten a makeover! We've given the interior of the two lobbies a thorough clean-up and made it easier for you to create new projects. We've also cleaned up the canvas a bit, and don't worry, all of your canvas features are still available in the little menu in the bottom right corner.
Feedback wanted
This is just the beginning. With this update comes a promise and commitment to keep improving and listening to your feedback. If it's not too much to ask, please help us become even better by sharing your ideas for improvements, and your awesome creations with the LEGO Powered Up app.
This message can be shared with your community. We will be collecting your questions posted in this thread and deliver them back to the technical hardware team in mid-January. Any answers we have will then be posted here.
Matthes_CS
Takže PUP přebírá C+? Jsem zmaten.
Ale vypadá to, že se vyřešil ten problém s vlakovými motory, co jste řešily, když jdou dva motory spárovat, ale jen dva, jestli to chápu dobře.
vico
Super, to se docela hodí, řešil jsem, jak ovládat Boost Hub ve vlastním modelu, když má připojený jiný motor. Originalní Booost aplikace to neumožňovala a PUP aplikace obsahovala jen část bloků, např. chyběl blok pro otočení o určitý úhel.
Tak že by jednou LEGO něco vylepšilo? Nechám se překvapit :D
vladdo
neviem ci sa mozem aj tu opytat. Mam Powered Up v3.8.0.
Chyba my tam funkcia invert +-.
Mam 4 smerovy joystick 1 motor vpred vzad a druhy otacanie. Otacanie ide dobre , akurat pohyb ide naopak-  dozadu namiesto dopredu.
AKo zmenit smer?
Dakujem
racco42
vladdo
Dakujem funguje.
Este sa chcem opytat, joystick sa my vrati sam do strednej polohy, ale kolesa ostanu vytocene. Ako spravit aby sa sami dali na stred?
