Malý Lugbulk pro společné projekty 2017
Založil Igorus, 29.08.2016, 16:31:35
Igorus
#90
Finálně finální seznamy:
Friends
NIDObrázekNázevBarvaBL IDElement IDProjektpoznámka
1.Window 1 x 2 x 2 Reddish Brown605924595814friends
2.Window 1 x 2 x 2 White605924521210friends
3.Slope 45 2 x 4Dark orange30376115263friends
4.Brick 1x1Bright Light Orange30056061685friends
5.Brick 1x2Bright Light Orange30046003003friends
6.Brick 1x4Bright Light Orange30106003004friends
7.Brick 1x1White3005300501friends
8.Brick 1x2White3004300401friends
9.Brick 1x4White3010301001friends
10.Brick 1x1Medium Levander30054651903friends
11.Brick 1x2Medium Levander30044623598friends
12.Slope 30 1 x 1 x 2/3Reddish Brown36764504376friends
13.Plant Leaves 6 x 5 Swordleaf with Clip Green108846097473friends
14.Plant with 3 Large LeavesGreen62554106895friends
15.Plant Sea GrassBright green300936059027friends
16.Plant Leaves 6 x 5Bright green24174129872friends
17.Plate 16 x 16Tan914054611414friends
18.Plate 1 x 2Lime30234164037friends
19.Slope 30 1 x 1 x 2/3Lime542004504372friends
20.Plant Leaves 6 x 5 Swordleaf with ClipLime108846023832friends
21.Baseplate 48 x 48Blue41866030733friends
22.Brick 1x4Tan30104113916friends
23.Brick 1x2Tan30044109995friends
24.Brick 1x2LBG30044211388friends
25.Brick 1x2Bright Light Blue30046100322friends
26.Plate 16x16Green914054626702friends
27.Hose, Rigid 3mm D. 28LReddish Brown75c286040310friends
28.Brick, Round 1 x 1Dark orange3062b6074890friends
29.Brick 2x4dark tan30014247145friends
30.Plate 1x2Bright Light Blue30234649765friends
31.Base Plate 16x32Blue38574226002friends
32.Slope 45 2 x 2 Double ConvexDark orange30456115260friends
33.Slope 45 2 x 2Dark orange30396115261friends
34.Slope 45 2 x 1Dark orange30406069259friends
35.Round 1 x 1 with Flower EdgeDark Pink 332914216479friends
36.Cone 1 x 1 with Top GrooveReddish Brown4589b4529242friends
37.Plate, Modified 1 x 2 with Clip Horizontal on EndReddish Brown638686008297friends
38.Plate, Modified 1 x 2 with Handle on End - Closed EndsReddish Brown604786102975friends
39.Roof tile 1 x 1 x 2/3Dark Orange  542006104342friends
40.Roof tile 1 x 1 x 2/3Sand blue542006062686friends
41.Roof tile 1 x 1 x 2/3Dark red542004531415friends
42.Base plate 48 x 48LBG41864278193friends
Igorus
#91
Micropolis
1.Plate 1 x 2Transparent clear62254167842micropolis
2.Tile 1 x 1 with GrooveTransparent clear300396047501micropolis
3.Tile 1 x 2 with GrooveTrans-Black 30694529685micropolis
4.Tile 1 x 1 with GrooveTrans-Black 3070b6038458micropolis
5.Plate 1 x 1Trans-Clear 31243000840micropolisDostupné též ve Vídni
6.Plate 1 x 2Trans-Light Blue 30236051918micropolis
7.Plate 1 x 2Trans-Medium Blue 30236121436micropolis
8.Plate 1 x 1Trans Black31246030982micropolis
9.Modified 1 x 1 with Studs on 4 SidesLight Bluish Gray47334211511micropolis
10.Plate 1 x 3sand green36236069257micropolis
11.Plate 1 x 4Sand Green37106100234micropolis
12.Plate 1 x 1Trans-Light Blue 30246051920micropolis
13.Tile 1 x 1 with GrooveTrans-Light Blue 3070b6051921micropolis
14.Tile 1 x 2 with GrooveTrans-Light Blue 30694667222micropolis
15.Brick, Modified 1 x 1 with HeadlightTan40704118793micropolis
16.Brick, Modified 1 x 1 with Stud on 1 SideTan870874579260micropolis
17.Tile 1 x 1 with GrooveDark Bluish Gray30704210848micropolis
18.Tile 1 x 2 with GrooveDark Bluish Gray30694211052micropolis
19.Tile 1 x 1 with GrooveLight Bluish Gray30704211415micropolis
20.Tile 1 x 2 with GrooveLight Bluish Gray30694211414micropolis
21.Plate 1 x 1Light Bluish Gray30244211399micropolis
22.Plate 1 x 2Light Bluish Gray30234211398micropolis
23.Plate 1 x 2Dark Bluish Gray30234211063micropolis
24.Tile 1 x 4 with GrooveLight Bluish Gray24314211356micropolis
25.Tile 1 x 4 with GrooveDark Bluish Gray24314211053micropolis
26.Tile 1 x 2 with GrooveDark Green30696055171micropolis
27.Plate 1 x 1 w. up right holderLight Bluish Gray157126071229micropolis
28.Plate 1 x 4Light Bluish Gray37104211445micropolis
29.Plate 1 x 6Light Bluish Gray36664211438micropolis
30.Plate 2 x 4Light Bluish Gray30204211395micropolis
31.Plate 1 x 1Black3024302426micropolis
32.Plate 1 x 2Black3023302326micropolis
33.Plate 1 x 4Black3710371026micropolis
34.Plate 1 x 6Black3666366626micropolis
35.Plate 2 x 4Black3020302026micropolis
36.Plate 1 x 1Tan30244159553micropolis
37.Plate 1 x 2Tan30234113917micropolis
38.Plate 1 x 4Tan37104113233micropolis
39.Plate 1 x 6Tan36664124067micropolis
40.Plate 2 x 4Tan30204114309micropolis
41.Tile 1 x 3 Redish Brown638646100769micropolis
42.Brick, Modified 1 x 1 with Stud on 1 SideDark Bluish Gray870874558955micropolis
43.Brick, Modified 1 x 1 with HeadlightRedish Brown40704225469micropolis
jerzeeg
Citace od: Igorus kdy 19.10.2016, 12:25:25
Termín finalizace objednávek je do neděle 26.10. (ale viz bod ,,Další kroky")
V Nedeli je 23.10. :)
Pochopil jsem spravne, ze - kdyby se neco hodilo - mohu vybirat z obou seznamu, i kdyz se ucastnim pouze Friends projektu ?
Predpokladam s tim, ze limit 2000 DKK by byl spolecny pro oboji ?
(Mikropolis jsem zvazoval, ale netroufam si casove apod.)
Citace od: jerzeeg kdy 19.10.2016, 15:13:24
Ano (limit celkový 2000, možno dílky z obou seznamu), cílem je podpořit stavitele.
Škoda že k těm oknům nejsou skla 60601, možná by šly dodatečně vyměnit za díl co nikdo nebude chtít?
Třeba ta tmavě zelená Tile ze seznamu Micropolis se podle mě hodí na terén do Friends. Možná i ve větším množství než bude potřeba v Micropolis, s ohledem na velikosti terénů tam :) Takže taky budu určitě koukat do obou seznamů a kombinovat to.
Limity
Vystavovatelé – limit 2000 DKK na projekt
Nováčci (do nyní nevystavovali, mladší 18 ti let) – limit 1000 DKK
Citace od: peki kdy 19.10.2016, 21:18:21
Měl bych k tomu výše citovanému otázečky:
1) Chtěl bych se zeptat, jestli limit je na projekt nebo na osobu? Tedy když se někdo účastní obou projektů, tak jestli může čerpat na každý projekt ten limit (tj. vlastně celkově dva limity).
2) Když jsem se neúčastnil předchozího LB, ale už vytavuji nějaké věci na Kostkolandu (mod. dům na kolejiště, dvě filmové scénky, model do soutěže alt. modelů), tak jestli už mohu čerpat ten vyšší limit jako vystavovatel?
Předem díky za info
Citace od: Pool kdy 20.10.2016, 12:50:49
Předem díky za info
1) Limit je na projekt.
2) Bude posuzováno individuálně. Nicméně pokud někdo "už" vystavuje v Koskolandu je vystavovatel.
Takže ty konkrétně můžeš  jsi vystavovatel ;)
Cílem "restrikcí" není nějaká zlovůle ze strany adminů, potřebujeme aby se materiál dostával k lidem co staví.  Abychom pak neřešili situace typu končím s LEGEM vše rozprodávám.
Super, nebo spíš double super  ;D, tak to mám předčasné Vánoce  ::).
Martins
Kdepak, tos pochopil úplně špatně! O Vánoce si tímto definitivně přišel, protože ses upsal Čertu i Ďáblu a budeš stavět, až se z tebe bude kouřit...  :D
Citace od: Martins kdy 20.10.2016, 16:03:35
Uvidíme kdy to dorazí.Určitě až 2017.
Citace od: Pool kdy 20.10.2016, 13:29:10
Citace od: peki kdy 20.10.2016, 19:28:30
Takže nakoniec nebudeš mať ani Vianoce, ani dieliky z Lugbulku. ;D
Igorus
Já bych to tak negativně neviděl. Minulý rok se objednávalo 8.12. a už 18.12. přišel první balík  ;)
Našel jsem v tom seznamu Mikropilisu chybku u položky 26. zelený Tile.
3069 - je Tile 1x2, což souhlasí i s textovým popisem
6055171 - je Tile 1x1, což souhlasí zase s obrázkem
Na trávu to je jedno, takže beru jakýkoliv  >:D, ale spíš aby to pak při objednání nějak nevyřadili, že by jim nebylo jasné, co vlastně chceme  ;D
Dobrá připomínka. Ještě u položek 5 a 8 v seznamu pro Micropolis jsou špatně čísla dílů: místo 3124 má být správně 3024. A tu rostlinku se třemi listy zná BL jako "x8".
ElementID jsem nekontroloval, na ty nemám "hromadné udělátko".
Když už jsme u toho ve Friends sedmý od konce Reddish Brown Slope 30 1 x 1 x 2/3 má mít BL ID 54200 místo 3676, ale kupuji podle obrázků, tak ty snad sedí.
Igorus
Ono je to obecně v rámci každého LB, kdy primárně to je na základě element ID. BL ID je orientační.
Kažodpádně díky za upozornění.
Igorus
Igorus
Limity pro oba malé LB nastaveny na 2000 DKK.
Igorus
Připomínám, konec objednávek pro účely prioritizace je ve středu tj. 26.10.2016.
janopr
Dotaz: Mám v aplikaci klikat na "uložit a uzavřít (objednávám)", i když se bude ještě prioritizovat? Nebo stačí zatím "uložit a přepočítat"?
Igorus
Citace od: janopr kdy 26.10.2016, 15:52:01
Stačí "Uložit a přepočítat"
Igorus
Objednávky jsou uzavřeny. Probíhá prioritizace.
Igorus
pro info:
Vyřazené díly pro projekt Friends:
Igorus
Pro info:
Vyřazené díly pro micropolis:
A co ty sklíčka k oknům, půjdou přidat?
janopr
Citace od: Chairudo kdy 27.10.2016, 10:52:47
Ty jo, říká se, že pozdě honit Fibicha, ale za ta sklíčka bych se taky přimlouval. ::)
Citace od: janopr kdy 27.10.2016, 10:57:35
Typuji že každý kdo bral okna  :D
janopr
Glass for Window 1 x 2 x 2 Flat Front
trans clear
Lego ID: 6024020
BL:60601
Igorus
Co se týká sklíček tak odpověď je ne, nebudou se přidávat do aplikace. Ta neumí jednoduše přidávat díly do již rozběhnuté objednávky.
Aktuálně jsou navíc ve velkém LB 2016, tedy někteří je dostanou současně s dalšími díly. Ostatní musí objednat samostatně.
