Návrh castle projektu pro Lipno 2014
Založil danyboy, 28.08.2013, 13:43:04
danyboy
Ještě pro jistotu jakou barvu cesty preferujete?
Prosím napište názor:
blackrabbit
Citace od: danyboy2127 kdy 28.12.2013, 17:28:19
DkTan
Izmael10
Dark tan, možno dlaždice na hrade.
TAN s darkTAN/hnědými kolejemi...
danyboy
Jsem také pro Dtan, sem tam nějaké brown fleky i ty koleje by nebyly špatné..
SpCasPi000
#65
Mimo hradu DarkTAN v suchom stave, doplniť (tmavo)hnedou, zelenou, DBG ak je stav mokrý...  ;D
V hrade sa najviac hodí asi LBG, s trochou DBG niekde.
https://www.google.sk/search?q=stredoveká+cestná+sieť+na+pohroní+a+poiplí&client=opera&hs=uhw&source=lnms&tbm=isch&sa=X&ei=iRnAUpnlDubJ4ATX-IHoBA&ved=0CAcQ_AUoAQ&biw=1280&bih=954#q=middle+age+road&tbm=isch&facrc=_&imgdii=_&imgrc=dTGUdpSkLxRb9M%3A%3Bwgn_sP42URSTmM%3Bhttp%253A%252F%252Fslowmuse.files.wordpress.com%252F2009%252F11%252Fhighhead.jpg%3Bhttp%253A%252F%252Fwww.slowmuse.com%252Ftag%252Fhigh-head-castle%252F%3B2160%3B1620
https://www.google.sk/search?q=stredoveká+cestná+sieť+na+pohroní+a+poiplí&client=opera&hs=uhw&source=lnms&tbm=isch&sa=X&ei=iRnAUpnlDubJ4ATX-IHoBA&ved=0CAcQ_AUoAQ&biw=1280&bih=954#q=middle+age+road&tbm=isch&facrc=_&imgdii=_&imgrc=hx42Yhmwy2lipM%3A%3BOPy7fS3s8dFevM%3Bhttp%253A%252F%252Fwww.mattigronroos.fi%252FTiet%252FVt3_Anomaa.jpg%3Bhttp%253A%252F%252Fwww.skyscrapercity.com%252Fshowthread.php%253Ft%253D1607614%3B750%3B500
http://www.google.sk/imgres?imgurl=http%3A%2F%2F4.bp.blogspot.com%2F-t6olj3Ymkq4%2FTg7bbIH_wLI%2FAAAAAAAAIZ4%2FYkwtAd5jThQ%2Fs320%2FStone%252Bpaving%252Band%252Bwalls%252Bin%252BMinerve.jpg&imgrefurl=http%3A%2F%2Fdiane-emerson.blogspot.com%2F2011%2F06%2Ffrench-deshe-and-desherbe-late-may.html&docid=B9VRhXkh-4jV-M&tbnid=HxWYtI5UoxCr5M&w=480&h=640&ei=Sx7AUvqkN-KQ0AWdl4DQDQ&ved=0CAkQxiAwBw&iact=c
http://www.google.sk/imgres?imgurl=http%3A%2F%2Fstatic.panoramio.com%2Fphotos%2Flarge%2F51551092.jpg&imgrefurl=http%3A%2F%2Fwww.panoramio.com%2Fphoto%2F51551092&docid=YdLDbFGJqdZb4M&tbnid=WkQLaitJl1LsNM&w=1944&h=2592&ei=Sx7AUvqkN-KQ0AWdl4DQDQ&ved=0CAQQxiAwAg&iact=c
https://www.google.sk/search?q=stredoveká+cestná+sieť+na+pohroní+a+poiplí&client=opera&hs=uhw&source=lnms&tbm=isch&sa=X&ei=iRnAUpnlDubJ4ATX-IHoBA&ved=0CAcQ_AUoAQ&biw=1280&bih=954#q=middle+age+road&tbm=isch&facrc=_&imgdii=hx42Yhmwy2lipM%3A%3Beihx0zZ0uIOEDM%3Bhx42Yhmwy2lipM%3A&imgrc=hx42Yhmwy2lipM%3A%3BOPy7fS3s8dFevM%3Bhttp%253A%252F%252Fwww.mattigronroos.fi%252FTiet%252FVt3_Anomaa.jpg%3Bhttp%253A%252F%252Fwww.skyscrapercity.com%252Fshowthread.php%253Ft%253D1607614%3B750%3B500
http://www.google.sk/imgres?bih=954&biw=1280&tbm=isch&tbnid=pWPtYazNGCz94M:&imgrefurl=http://amadisofgaul.blogspot.com/2010/09/chapter-36-first-part.html&docid=b-rJig3ZJsCMeM&imgurl=http://1.bp.blogspot.com/_K38EAA9YNOs/TIXFX8sGUWI/AAAAAAAAAWQ/soxsNnwa9xg/s1600/RomanRoad.JPG&w=500&h=667&ei=wR_AUoTeC6Wz4AT8pYDgBQ&zoom=1&ved=1t:3588,r:6,s:0,i:97&iact=rc&page=1&tbnh=183&tbnw=152&start=0&ndsp=26&tx=94&ty=71
danyboy
#66
Já na nádvoří začal stavět cestu z reddish brown. V podstatě je to blátěnka vytvořená vlhkem a
ruchem na nádvoří, do toho vkládám sem tam dlaždičky.
Cesta kolem hradu by mohla být klidně kamená, jen já si nejsem jist materiálem.
Jak vidím, zatím vyhrává barva dark tan a do toho fleky.
danyboy
#67
Souhlasíte teda všichni s výškou půdy 2 bricky?  ???
Pro přehled a konečné zhotovení mapy bych byl rád, kdyby jste svojí představu popsali v tomto vlákně.
A také chci od všech vědět předpokládané rozměry. ;)
Izmael10
#68
Takže ako sme sa už dohodli ja budem stavať druhý hrad, ktorý bude napojený mostom na tvoj hrad.
Plánujem tak 4x3 baseplates 32x32.
Výška terénu môže byť 2 bricky.
danyboy
Citace od: Izmael10 kdy 02.01.2014, 12:57:49
Plánujem tak 3x3 baseplates 32x32.
Výška terénu môže byť 2 study.
Ok, souhlasíš se sousedem BlackRabbit?
Budeš mít baráčky u hradu!  >:D
Izmael10
#70
Môže byť. Pokiaľ mu nebude vadiť obrovská skala, ktorou bude končiť moja časť Castle projektu.  ;D
Blackrabbit: Ak tam budeš mať aj stromy tak ich daj ďalej od hradu, lebo v úplnej blízkosti hradov moc stromov nebývalo.  ;)
to výška 2study - myslíte asi spíš 2 bricky žejo? ;) A jak už jsem říkal dannymu, tak to je fakt málo - já tak vysoko plánuju hladinu vody. terén bych dal určitě výš - vloni to bylo mezi 4 až 6 bricky. Líp to vypadá když to je výš nad vodou, a jde si vyhrát s terénem - konkrétně s nějakým zahloubením - výkopy apod...
danyboy
Citace od: germik kdy 02.01.2014, 17:33:43
Došlo k překlepu, no. Opraveno.
Jak jsem psal, klidně udělej více, stačí se domluvit se sousedem.
Já kvůli velkému prostoru nechci moc terén zvyšovat. Nedal bych to s materiálem.
Na zvýšení terénu o jeden brick pro plochu 32x32st podle mně stačí maximálně tak 25bricků 2x2... Ale ok, uvidím ;)
Ještě unifikace termínů - jak budem nazývat jednotlivé rozměry? >:D
výška terénu - výška
od předu dozadu - hloubka
od souseda k sousedovi - šířka
ánebo výška, šířka délka?
Jinak já za sebe zvládnu hloubku jak bude, tzn asi těch 96st, a na šířku/délku 64, max 80 - víc nejspíš nezvládnu...
Může být? Kdo teda bude z druhé strany?
Zvládáš Sakorasi tu řeku? Šířka by měla být zhruba 20 st, rozmýšlím jestli ji udělat z bricků naležato nebo na ně ještě dát round plates (říkal Danny že prý jdou sehnat za 11haléřů - když bych počítal 4ks na stud čtvereční, tak to vychází asi na 40kč za plochu 10x10st...
Letos nechci dělat přímo mlýn, ale vodním hejblatům věrný zůstanu - říkal jsem si třeba pila nebo něco takového... A otázka na Akiho - mohla být takováto stavba třeba opevněná? Já tam prostě někam tu šedou použít chci ;D
danyboy
Citace od: germik kdy 02.01.2014, 18:07:20
Ok?
Dobře, už jsi se rozhodl jak uděláš tu vodu?
VocucBat
danyboy
Citace od: vocucbat kdy 02.01.2014, 18:36:33
Sám zvládnu tak 32x32 ;D
Žadná problema.
Však to nějak vyřešíme. :P
jestli chceš kapli vedle hradu, tak nechám  zub do kterého to strčíme.
No, ale to je trošku realistická blbost. >:D
danyboy
Není ta střecha až moc divná?  ???
danyboy
Při dnešním kurzu vychází na +- 14 haléřů, ale musíš si zajet do PaB walls.
Střecha má malý (vlastně skoro žádný) sklon. Hlavní je ale samotný domek - musíš si uvědomit že to černý je trám, který tvoří nosnou kostru domu - zbytek je jen výplň z hlíny a proutí - proto musí ta kostra být souvislá a bez přerušení třeba oknem nebo dveřmi, a proto v horní části domu pár trámů chybí... A rám okna by byl lepší jiný než Tan ;)
Ty round plates... já pořád nevím - vím že to vypadá docela dobře, ale podle mně ty bricky naležato stačej... Případně bych do toho ale za cenu těch 14 halířů snad byl ochoten jít (jestli by mi teda ty dílky odtama někdo přivezl ;D)
danyboy
Citace od: germik kdy 02.01.2014, 19:57:51
Střecha má malý (vlastně skoro žádný) sklon. Hlavní je ale samotný domek - musíš si uvědomit že to černý je trám, který tvoří nosnou kostru domu - zbytek je jen výplň z hlíny a proutí - proto musí ta kostra být souvislá a bez přerušení třeba oknem nebo dveřmi...  ;)
Pokud ještě pojedeme do Alp, tak myslím, že nebude problém stavit se v PaB. >:D
________________________________________________________________
P.S, Domek se pokusím, ještě dnes poupravit.
Střecha má sice malý sklon, ale to by až tak nevadilo. Je to jen "chatrč". Horší je, že začíná strašně nízko a pak ta dřevěná konstrukce jaksi absentuje (jak už pěkně popsal Germik).
Ideálně by ale takový domek mohl vypadat nějak takhle: link
To Germik: sice u nás o žádném opevněném mlýně nevím, ale typoval bych, že někde ve Francii by něco podobného být mohlo. Určitě by to vypadalo jako opevněný dvorec, co jsme se o něm bavili již loni. O opevněné pile, nebo hamru bych ale už neuvažoval.
Nevidím, ale problém aby jsi udělal (zase  >:D) mlýn celý kamenný... 8)
Citace od: danyboy2127 kdy 02.01.2014, 19:41:17Není ta střecha až moc divná?
Divná je a myslím si, že jí nejvíce vadí, že je z tiles. Osobně, pokud bych ji stavěl jako ty, tak bych ji udělal čistě z plates, např. tak jak ji udělal Ass ve svém Italském MOCu.
danyboy
Citace od: peter kdy 03.01.2014, 09:25:34
Vyzkouším. Tak záměr zbavit se podložek z CMF nevyšel. >:D
Kuba
#84
Mi se ta střecha zas tak moc divná nezdá, pokud by byla s přesahem i do boků, bylo by to možná lepší. Nebo ji zkus mírně zešikmit,  tak jak jsem to udělal ve westernu u Hl. budovy v pevnosti, nebo u budky u zlatého dolu. (Na mírně zešikmenou plate desku jsem pokládal stupňovitě tiles).
Otázkou je, jak tiles na některé působí u středověké chatrče? U těch modernějších budov vypadaj tiles na střechách ale božsky.
Potřebuji 2 věci:
1) potvrdit rozměr vašeho dioránatu (ideální pokud by jste využili i roh)
2) vyjádřit se v tématu jestli máte zájem o nějakou formu podpory (ta je pro všechny vystavovatele na LP 2014)
danyboy
#86
Tak, jelikož nám dva stavitelé vypadli, tak mi vychází délka nějakých 5,5m.
Podle předpokladů, že postavíte opravdu tak velké MOCy.
danyboy
Máme stále loných 1,5m.
Něco by měl ještě doplnit vocucbat, ale i tak, nám zbývá dost místa.
Stále je možnost účastnit se tohoto projektu.
Kdo by chtěl nějaké bližší informace. Napište mi SZ.
Přikládám mapu. Nákresy hradů jsou jen pro orientaci. Nikdo neříká, že takhle bude hrad
ve finále vypadat.. ;)
To tedy nevím jak jste se domlouvali, ale Sakorasovi půjčím matroš tak maximálně na šířku dvou baseplate (64 studů / 52 cm). A podle toho co tu máme rozestavěné, tak směrem k Vasanovi bude řeka (takžedalší řeka?) a v popředí bude těžko les, to by tábor jednak nebyl vidět a druhak má být tábor opevněný, takže les by byl maximálně jen pařezový.  >:D
danyboy
Citace od: Aki kdy 26.02.2014, 07:31:06
Hele, on by se nejprv měl začít ozývat.
Co mi poslal jako návrh, tak jsem mu převedl do toho plánu.
Ať se ozve.  ;)
